- Feb 5, 2001
- Calgary, Alberta, CanaDuh
I decided to install Linux on me gaming rig, I resized the partitions, and installed debian....got pretty much to the end, and...oops, video error, cannot start Mach64 X server. But i'm not using my Rage pro (Onboard nic) I have it selected to use my Geforce as primary in BIOS. Oh, but Linux is a B**tch, and seems to be running on my geforce, but only "sees" my rage pro.
I seem to be having a little bit of a problem here, and it's a real pain. The only way to run linux is to select my onboard nic (ATI Rage Pro AGP2x) as default. But then windows doesn't work because it's set up to use my GF2MX PCI as the primary, and disable the ATI. Even if I did set windows to use my ATI, it would defeat the purpose of even having a Geforce.
Why does Linux only see my onboard AGP card, even if everything is running on the default PCI card? How can I fix this? This is kind of confusing. It was running itself on my geforce, yet still thought that it needed to use my Rage Pro.
Help!
BTW: I also tried reinstallation many times, on different distros as well (RH6.1), and got the same result. And no, upgrading to a decent mobo with an agp slot and new gfx card are not an option....yet (Need money :>)
Help!
