- Sep 15, 2004
- Nebraska
That worked. Thanks.
Thanks Mr. Chambers! I figured out how to uninstall it too by searching the registry for FAH4Console and then deleteing the FAH key folder. But thanks to you I can now still run it if I want, turn its cycles down and stop it when on battery power.
thanks again!
Rob
Mr. Chambers said:Start -> Run -> type "services.msc" (without the quotes), then scroll down to "F@H", right-click, and choose "stop". That will stop the service. Or you could edit your client.cfg file to only use 50% of CPU cycles...
thanks again!
Rob
