- Oct 5, 2008
- Cumbria (UK)
Got a strange problem I can't seem to figure out.
I have just changed the motherboard in my fileserver to a ASUS P5Q Deluxe.
The main reason I bothered to change the board was because it has two LAN ports that can be teamed together in software so I don't require a smart switch.
The NIC's are Marvell 88E8056
Problem is only one port shows up in device manager.
Both NIC's are enabled in the BIOS and they are no unknown devices in device manager.
Using the drivers from the Asus website doesn't even give teaming as an option but using the drivers directly from Marvell do. But of cause I can't team as only one NIC shows up
I've no idea what the problem is
My server is running Windows Server 2012.
