Only 3.1 on a 2.8 M0 Stepping? eh? (Quake3 Artifacts @225FSB? - From CPU Overclocking
Hi all,
Quick question for you.
If I run the below system at 225 FSB 1:1 Ratio with the RAM at 3,3,7,3 (this RAM is supposed to hit 250 FSB at those timings) the system runs fine, Doom 3 runs fine, Need For Speed 2 Underground, 3DMark 2001 for hours on end. (Even Memtest86 will loop for hours)
But... When I run Quake 3, or Grand Theft Auto: Vice City I get Artifacting? Even slightly in the Quake menus. Dropping to 215 FSB (1:1 again) it goes away.. Also if I run at 225 FSB but with the 5:4 ratio on, it does away.. (almost suggesting the RAM? but that doesn't make sense as this RAM tests fine and will even run at 215 FSB at 2,2,5,2 (as rated)
I've upped the DDR Voltage to 2.95v (from 2.8) and it's still there..
My AGP Voltage is 1.55 Normally, so I upped this to 1.6v and still artifacting at 225 FSB
and the CPU Core is currently at 1.6v (from 1.525v) still the same
(For all tests above the graphics card is a 'default' ATI Speeds.)
Even up to 230FSB the system runs fine, just the artifacting in Quake 3 etc. gets worse, Doom 3 is fine and the system never crashes?!? (I've heard if anything will crash a PC or show weakness it's something like Doom 3 or NFS:U2 not an old game like Quake 3 ) and I always though artifacting/ flickering textures was to do with a graphics card overclocking problem not the CPU?
Any ideas anyone? I was hoping to hit 250FSB with this system.
Temperature isn't a problem as the system has lots of nice 92mm fans now and a new heatsink (plus sinks on the MOSFETs).
Any advice appreciated
Thanks,
Hi all,
Thanks,
