This will be my second build. About to start my first simple build currently.
Money and confidence purposes i want to start with a single gpu and a non overclocked cpu. Because of this i am unsure if i need a cpu heatsink initially. But then again it would be easier to put the heat sink on before i install the motherboard.... What opinions do you have on this and what cpu cooler would you recommend? This is what i am thinking for the final build. Hardware opinions?
Like i said at first i will not be overclocked or have dual gpu's. I took into consideration that i would expand to that when picking a psu. Is 1000w enough for the end result?
Is this motherboard overkill? I thought it would work well with the i7 and i like that i should not have to add a audio, wifi, or bluetooth card.
Any thoughts on the ram i chose? would i be better off going with 4x4 gig cards. I just thought i may want to expand past 16 gig in future even though it is way overkill currently.
Hard drives are just cheapest i could get with space i wanted. Any better deals? am i missing something?
Man i like the look of this case, comes with two fans. figure i add three more will be more than enough air movement. Should i get a fan controller think? Anyone have any experience with this case?
I have no idea how long i will run single gpu and non overclocked. Probably a couple months till i get bored.
This is mainly a gaming build. Dayz, Diablo 3, eso, civ v, skyrim, ect.
PC will be a main media hub in my living room as well, so may add another or larger hard drive.
Any opinions welcome, thanks...
PC Builder - Intel Core i7-4790K, 2 x GeForce GTX 780 Ti, Cougar Challenger ATX Mid Tower - PCPartPicker
pcpartpicker.com
