- Oct 26, 2002
- Northern Virginia
I'm almost ready to buy my first WC setup and have been looking at a MWC6002, a AquaXtreme 50Z-DC12 from D-Tek and a Pro-120 radiator using 1/2" ID tubing. I'm only cooling my P4 2.4C and maybe a 3.2E in the future.
After reading some other posts and looking athe graphs at Pro Testing's site, the 6002 seems to have an advantage at lower flow rates than my other WB option, the D-Tek White Water, but loses at the high end.
Would the AquaXtreme 50Z-DC12/WW combo would give significantly better temps than with the 6002 and the AquaXtreme? Or is it overkilll to match up a 6002 with the AquaXtreme? It seems that the higher the flow rate, the lower the temps, so the AquaXtrreme/WW combo would provide the best performance.
Assuming that I went with the 6002, would a single CSP 750 be a better match?
I'm currently at 45C load and 30C idle with my Zalman 7000. I'd like to stay at least at these temps with a WC setup. Would I need to go with WW/AquaXtreme to get those temps, or would the 6002 do it? Thanks in advance.
