J☼E;8041190 said:This review had me worried
A hot mess and an overpriced paper launch: Intel's EPYC failure of an attempt of Ryzen to the occasion against AMD. Did you ever think the 7700K was slightly too hot for comfort in your build but barely managed anyhow? Take all the ills and missteps of the thermals of the 7700K and magnify them to unimaginable levels in this flagship mainstream processor. Though you would expect a mainstream-targeted processor outside of the HEDT X299 line to be entry-level builder friendly, the 8700K is actually more demanding than the 7800X and practically requires liquid cooling. In testing, the 8700K, with a $150+ premium AIO like the NZXT Kraken X62 or the Alphacool Eisbear 420, has been found to be up to 20 degrees hotter than its predecessor. Google "8700K temperature" and you will find numerous accounts of reviewers and users having temperatures in the 80 and 90 degree Celsius range while constantly hitting thermal throttling. Do not even remotely consider pairing a Cooler Master Hyper 212 EVO with this hot shot or throwing this fiery devil into a small form factor case like the RVZ02 or the DAN Cases A4-SFX. Intel is making the same mistakes from the darker times of its past and is returning to its Pentium 4 ways with this underwhelming, steaming pile of product. Practically speaking, Ryzen also achieves much greater than 60 fps in most games (not even the 8700K can achieve 144 fps+ for high refresh rate monitors unless you drop graphical settings to levels where Ryzen is practically on the same footing) and still has the upper hand in multi-threaded performance and power consumption. My strong suggestion: either (1) purchase a Ryzen 7 1700 processor and overclock it to 1800X levels, (2) wait until the 12nm Ryzen refresh comes out in February/March 2018, or (3) wait a bit longer for 7nm Zen 2 (SemiAccurate, a costly but highly reputable professional tech industry news outlet, affirms Zen 2 is still on schedule) to come out by the end of 2018. Less
J☼E;8041592 said:not sure, my bios automatically chose 1.4, I'm going to go in and bump that way down.
J☼E;8041604 said:prime stable at 5ghz 100x50 1.392v 118-120F for an hour
