- Apr 14, 2010
- Thread Starter
- #21
How would you connect fans to the motherboard though? The case fans only have the power cord to the PSU and a switch that allows you to change the speed between low medium and high (I keep mine on high).It will control fan speed by dropping the voltage/raising the voltage. As far as being about to control the fans from the MB you would have to look at how many fan pin outs are offered on your board. On my wifes board I can hook 2 additional fans and control them from the MB, yet on my board I think I can only hook one additional fan and control it from the MB so its up to the MB. You would have to look for a fan controller to set the fans to what you need in order to control the rest. The wifes Antec 1200 fans do not impress me at all and I ordered a couple of Scythe Gentle Typhoon 120 1850rpm fans yesterday, I intend to replace all 5 of the 120's in her case before its over.
Here's my motherboard:
http://www.gigabyte.com/products/product-page.aspx?pid=3038#sp
It says it's got:
1 x CPU fan header (I know where that is located.)
2 x system fan header
1 x power fan header
1 x front panel header
And lots of other stuff, that's the only fan-related stuff I found.
