- Nov 16, 2007
- Toronto, On, Canada
I've had my PC at a very minor OC from 2.66 to 2.88ghz for a while now.
I have in the past had it running @ 3.4ghz and even faster.. but after a few crashes and Orthos blend test failing - I'd reset it to default and make sure Orthos Blend test would run stable for 4 hours in order to keep my system from crashing.
Now I'm trying things out at 3,120Mhz to see if I can get a stable 3,120Mhz. 3dmark06 will complete, all my games run flawlessfly, Orthos "small FFT's" will run indefinatly and my CPU temp won't even rise above 50'C, 'stess CPU with gromacs core' again will run indefinatly and temps will never rise above 50'C. I know my cooliing isn't the problem. Dual PI 32M won't even pass on stock clocks, but single PI 32M always completes fine.
If I try running a 'CPU + RAM' blend test at any overclock past 2.9Ghz... it fails after 1-2 mins. (sometimes sooner) and I worry my system is becomming unstable or that I'm damaging it. I'm still relatively new to OCing, but I know most of the basics, and have been trolling these forums for a few months.
I'm asking for some advice as what my problem might be, I have a feeling its just my mobo (which is a crappy p5kc) that is giving me the hassle, but is their any settings in BOIS that might help me isolate the problem?
-I do have Vcore set to [default]... this is actually most stable from my tests.. the CPU voltage automatically adjusts as I clock it higher, and I've even tried up to 1.5V @ 3.1ghz, but I still get the exact same stability issue, and my E6750 should run @ 3.2Ghz, with 1.35V I would think, which is what auto Vcore adjusts it to with windows. If it was more stable at higher volts I'd simply keep it higher... but its made absolutely no difference to me so far. (cept slightly higher temps)
Since buying my rig I've got a new PSU (GameXstream to replace $10 PSU that came with Case)
I exchanged my RAM a few times too see if different RAM would be more stable, this made no difference.
I've also bought about 5 fans to make sure good airflow runs through my case -- and my temps are very low now.
When I OC, I run with:
[PCI (whatever it is) at 100]
[c1e disabled]
[transaction booseter disabled]
[VMware disabled]
[NBVoltage 2 notches above default]
[NB Termination Voltage: 2 notches above default]
[Ram @ 3-4-4-15 (now I've tried 5-5-5-15, and 4-4-4-15 - which is settings from website, 3-4-4-15 is just as stable as 5-5-5-15, Ram voltage I have @ 2.1V which is settings again from OZC website)
Since I feel my system should easily be 100% stable at >3ghz since I have decent air cooling, aftermarket CPU cooler and good overall cooling, but I can't seem to get a stable OC with "cpu + ram" blend past 3Ghz.. I'm asking for any tips or things I should check to see what the problem is and hopefully isolate it (my best guess is just that my mobo is crappy, but I'm not 100% sure of this)
Edit, I think its my RAM... memtest gave me a bunch of errors last time I tried running it - no matter what the settings, going to try changing sockets.
[c1e disabled]
[VMware disabled]
