- Aug 27, 2003
- Mississauga, Ontario
I can't believe it, finally I'm ready for everything, and now the RAM I really want is out of stock, and even discontinued everywhere.
it is the dual channel 2x4GB Samsung ram, MV-3V4G3D/US code, the one everyone raves about, i really want it, newegg is out, amazon.com will not send to canada, amazon.ca doesn't have it, i'm in a pickle, and have no interest in any other ram.
Does Samsung have a new line coming out? I should have bought for $30 a month ago but figured I'll buy it with the GB UD-3 990FX and the 8150cpu *EDIT: Just found out about the 8350, please shed some light on that, worth it or is it just a 8150 overclocked at the factory?), but now I either have to choose a comparable 2x4gb kit for the above mobo/cpu combo, or get used, or find a store, I'm at my wits end, I was ready to buy everything, now I got nothing. You can't imagine my frustration.
any suggestions?
http://www.newegg.com/Product/Product.aspx?Item=N82E16820147096
another place that has stock with shipping to canada would be ideal, but...
I know Mushkin and OCZ and other companies have great ram, but none have a ram that is so cheap, and has low voltage and can be O/Ced incredibly and even the timings lowered, so this ram in particular, with no heat spreaders, and so cheap looking, is so incredible, I can't bring myself to buy some cool looking ram just because it looks cool, even if it can be comparable at the top end, but is also double the price.
If someone can offer a suggestion on how to get this particular ram, or a ram that is just as good (even if a bit more expensive, $50 I'd be willing to shell out for 2x4GB) and specifically made for the above mobo/cpu combo, and also have at least 9-9-9-24(28)T timings at 1866mhz, or a bit higher timings at 2000Mhz, that would be enough for me, but the priority is the samsung.
Thank you for your help..
Oh, btw, should I consider something other than the GB 990FXA UD-3 and 8150? I know there is new stuff out there, I cannot afford a 16 core opteron forget about that, but who knows whats out there now, and maybe a non Gigabyte board is better for similar price? I set up my friend and was surprised to learn the BIOS doesn't even have an option to save to different slots, the settings, and he has the UD5.. hmm.. I just need the usual, USB3 etc, no need for the next gen PCI slots, I have the 470GTX (which I want to trade for a 5 or 6 thousand series ATI, since I always preferred ATI to NVidia, and also because it goes with AMD like bread and butter, but my 3870 was getting old, so I had to, and I got it for cheap, but I don't notice any difference meaning my rig right now (sig) is the bottleneck.
Thanx (again) in advance.
any suggestions?
