- May 4, 2011
Hey guys.
So I haven't been looking at new pc parts in awhile, so I fell out of touch a bit.
The rundown: Starting today, my pc began to randomly shut itself down and reboot. So, After much reluctance, I fear I may finally have to bite the bullet and plunge into a new mobo/CPU/PSU/RAM.
Temps on hwmon, speccy, coretemp, speedfan are all nominal, tested and reproduced by running prime 95, a cpu strain causes it. So, I'm done, its getting axed
The videocard and harddrives are brand new, A nice EVGA GTX 770 2gb I got for a steal, and a shiny 120 gb Samsung 840 EVO. I have had these components for a few months, so It wouldn't make sense for them to be the culprits.
I don't need a new case, My NZXT Phantom is still plenty good enough.
My budget is as low as you can get it to be, with a hard ceiling of $650, but the less money I spend, the better.
AMD VS intel? Devil's canyon or *Whatever amd's chip is now.*
8 gigs of 1600 ram is preferred, low profile if possible.
I don't plan to SLI, so What would you recommend for a Power supply after said components?
Motherboard features will be determined based on intel/amd decision.
Current rig details are in sig. Thanks!
The games I play are Space Engineers, Planet Explorers, Star citizen, Eve Online, Kerbal space program, Skyrim, etc etc.
