hi guys
how do i set my 4gb OCZ PLATINUM
DDR2 1066 PC2 8500
Timing 5-5-5-18
Cas Latency 5
Voltage 2.1V - 2.2V after i've got intel q6600 go 2.4ghz -> 3.2ghz
What motherboard do you have? In the bios there should be an option to set the ram timings/settings called "XMP"(Extreme Memory Profile). Select that and the board will set the ram according to it's specs automatically
