I think you will achieve better results if you use a smaller CPU multiplier(multi is not locked downwards), try a few a few different steps downmulti while keeping the HT close to or below 1000MHz. The RAM is also able to take a bit of overclock, but do not try to overclock them CPU and RAM at the same time when doing the trials. After you found a stable peak for the processor you can try a bit OC on the RAM. A couple of samples :
Vcore up a couple of notch from stock ~ 1,4V
multi 12x
FSB 250
ht 4x
FSB : DRAM = CPU/7 or CPU/8
VDIMM up 1 or two notch if you want try /7 .
Multi 10x
FSB 300
HT 3x
