Hello,
I am trying to overclock my processor and have had moderate success so far but I want to push it more. My goal is to get my processor running close the 2600 mhz mark.
My setup:
3000+ Winchester 939
K8N Neo2 Plat
2x512 Kingston HyperX DDR 466
2x256 Kingston HyperX DDR 400
Antec NeoPower 480 Watts
Thermalright XP-90 Heatsink
Here are my current bios settings:
DRAM Configuration -
Max Memclock - 166 mhz
1T/2T timing - 2T
CAS Latency - 3.0
RAS# to CAS# (trcd) - 4
Min Ras# (tras) - 10
Row Precharge (trp) - 4
High Performance - disabled
aggressive timing - disabled
dynamic OC - disabled
Spread spectrum - disabled
HT Frequency - 4X
Cool'nquiet - disabled
CPU Ratio - 9X
CPU FSB - 250
AGP Frequency - 66 (default)
CPU VID - 1.50
CPU Volt - System/Startup (the only options are +3.3% of CPU VID or +5%)
Memory Voltage - 2.8
AGP Voltage - System (startup)
Summary:
Currenty -
9x250
HT = 4X
CPU 1.5 Volts
Memory 2.8 Volts
DDR - 166
Goal -
9x289
HT = 3X
CPU volts ??? (help here)
Memory 2.8 volts
DDR 133
Attempts:
I have gotten the machine to boot using the following:
9x270 Default CPU voltage
HT - 3X
2.8 Memory
Windows loaded, but 3dmark05 locked up.
Running higher FSB's I can sometimes get the machine to post, but when it gets to where it would normally load windows it just restarts. At other times I either get no video or the bios appears "corrupt" (gybberish and symbols appear on the screen).
Another part I have found some confusion is the CPU voltage. I'm seeing the bios show 1.5 as the default voltage, when I have read posts by useres that they are using 1.4, 1.425, 1.45 up to 1.55
CPUID shows my voltage as being 1.408-1.44. Does that CPU Voltage bios setting need to be adjusted? It's options are +3.3% CPU VID or +5%.
Also do the AGP voltage/frequencies need to be changed at all?
Any help, tips, and advice is appreciated!
My setup:
K8N Neo2 Plat
1T/2T timing - 2T
CAS Latency - 3.0
HT Frequency - 4X
CPU Ratio - 9X
CPU FSB - 250
CPU VID - 1.50
Summary:
Currenty -
9x250
HT = 4X
CPU 1.5 Volts
Memory 2.8 Volts
DDR - 166
Goal -
9x289
HT = 3X
Memory 2.8 volts
DDR 133
Attempts:
HT - 3X
2.8 Memory
