- Dec 27, 2008
DRAM: 1.55
CPU: 1.425. This is what you will be working with from here on out. It may need more. Should be safe up to 1.5 if temps permit. You want to keep core temps from exceeding 55-58c and CPU socket temps from exceeding about 65c or instability will set in.
NB: 1.225 volts and 2400 ghz in frequency (stock is 2400 mhz). Make sure you are changing the CPUNB votage and not the chipset NB votage. Can be confusing. The chipset has to do with the NB chip on the motherboard that controlls the PCI-e lanes. The section where each is found should tip it off.
Leave HT and VDDS at stock/auto.
Do you have LLC in bios?
