On Sat 3/17/2012 6:31:13 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031712-26176-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x7CD40)
Bugcheck code: 0xA (0xFFFFFFFFFFFFFFFF, 0x2, 0x0, 0xFFFFF80002A82366)
Error: [B]IRQL_NOT_LESS_OR_EQUAL[/B]
file path: C:\Windows\system32\[B]ntoskrnl.exe[/B]
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver which cannot be identified at this time.
crash dump file: C:\Windows\memory.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0x4DF97)
file path: C:\Windows\system32\drivers\[B]atikmdag.sys[/B]
product: ATI Radeon Family
company: Advanced Micro Devices, Inc.
description: ATI Radeon Kernel Mode Driver
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: atikmdag.sys (ATI Radeon Kernel Mode Driver, Advanced Micro Devices, Inc.).
Google query: atikmdag.sys Advanced Micro Devices, Inc. IRQL_NOT_LESS_OR_EQUAL
On Fri 3/16/2012 12:53:57 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031512-27783-01.dmp
This was probably caused by the following module: atikmdag.sys (atikmdag+0xF8969)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000094, 0xFFFFF88004B15969, 0xFFFFF88006BECFC8, 0xFFFFF88006BEC820)
Error: SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
Bug check description: This indicates that a system thread generated an exception which the error handler did not catch.
Google query: atikmdag.sys Advanced Micro Devices, Inc. SYSTEM_THREAD_EXCEPTION_NOT_HANDLED_M
On Fri 3/16/2012 12:16:06 AM GMT your computer crashed
crash dump file: C:\Windows\Minidump\031512-27019-01.dmp
This was probably caused by the following module: [B]atikmdag.sys [/B](atikmdag+0xF8969)
Bugcheck code: 0x1000007E (0xFFFFFFFFC0000094, 0xFFFFF88004B60969, 0xFFFFF88006BEAFC8, 0xFFFFF88006BEA820)
file path: C:\Windows\system32\drivers\atikmdag.sys
On Thu 2/23/2012 9:19:15 PM GMT your computer crashed
crash dump file: C:\Windows\Minidump\022312-13150-01.dmp
This was probably caused by the following module: [B]ntoskrnl.exe[/B] (nt+0x7CC40)
Bugcheck code: [B]0x101[/B] (0x31, 0x0, 0xFFFFF88002FD5180, 0x3)
Error: CLOCK_WATCHDOG_TIMEOUT
file path: C:\Windows\system32\ntoskrnl.exe
Bug check description: This indicates that an expected clock interrupt on a secondary processor, in a multi-processor system, was not received within the allocated interval.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem. This problem might be caused by a thermal issue.
