tym64, what are you testing stability of your settings with? The AMDOD stress test? If so, you will not impress anyone around here with your overclock. The AMDOD stress test is wimpy. Try the Prime95 blend test for at least two hours and see how she does on a vcore of 1.325.
The stress tests I use are OCCT for a hour, then Linpack for the next hour. Then I play crysis 2 for a couple of hours.
I respect people who don't agree with my "makes no difference overclocking" thoughts and opinions. Maybe it will help on other computers. Did nothing for mine. I am only talking about the fx 6100 chip.
You also need to ask yourself, is the risk worth the reward? Thats a personal choice. It will shorten the life of the cpu.
The biggest difference I have personally ever seen was changing harddrives from sata to solid state hard drive. That made some real world difference in my computer.
Just remember its only my opinion, Nothing more, After talking to some other overclockers, a few agreed with it, others did not. In the end, Its your computer, your risks. If you think the risks are worth the rewards, best of luck, in my case, No!! I am simply trying to express the flip side of the coin.
Always best to use common sense. Ok, You overclocked, Did it help tons? Then leave it, did it make no difference? Then maybe go back to defaults. I simply don't see much the warnings about what overclocking will do.
The only reason I added to the thread, Is hey maybe a few of my ideas will help others reach the goals there shooting for. Thats how I reached the 4.5 stable settings. Saw some dude on youtube use the AI Suite 2. Before I used it no luck with the 4.5. When I tried the settings in AI Suite 2, that was the answer for my computer.
