- Nov 11, 2012
Hello Guys,
I've just started overclocking and just bought a new cpu, the fx-8350 with motherboard gigabyte 970A-ud3. Cooler is a Corsair H80 water cooler kit. I tried some things, but don't seem to get a really stable overclock. I started with the multiplier and some fsb overclock. Whatever I do with the FSB, it seems that I cannot get it much higher then 205, so I left it to 200 mhz. Don't think it is worth tweaking it. I have tried the following with multipliers:
(y-cruncher is used for testing)
24x - 4800mhz, not stable and gives me hardware errors during test
23,5 - 4700 mhz, 55 degrees celcius, seems stable, but core frequency drop intermittently after a couple of minutes
22,5 - 4500 mhz, 52 degrees celcius, stable, but still some minimal frequency drops on full load.
I used cpu core voltages up to 1.51 in bios trying to prevent the frequency drops but that doesnt help. It runs now at 22,5x and 1.435 volts (fairly stable).
Bios setting changed:
load line control - extreme
amd c1e support - disabled
amd c6 support -disabled
virtualization - enabled (running VMWare)
amd k8 cool en quiet -disabled
amd apm master mode - disabled
core performance boost - disabled
Goal: try to get it stable at 4800 mhz
Got a couple of questions:
1. The frequency drops indicate that its not stable right? (y-cruncher runs fine without errors)
2. What am I doing wrong that causes me not getting it stable?
3. What temperature is the maximum for this processor to run safe? I have read low 60 degrees celcius, but is that true? Bulldozer was around 55 degrees I believe.
4. Does anyone have experience with this chip and what do you use for settings?
5. If not, what do you guru's advice me to do?
I have attached some screens.
