I got this bad boy a few days ago, and the previous owner confirmed that it runs prime95 for 24+ hours at 11.5x200.
Not wanting to destroy the chip the first day, I start taking it slow. I had been running for a couple of days @ 13.5x166, 1.625V, and it was rock solid (Folding, CPUBurn, Sandra(I don't know what the hell to do with prime95, so if anyone could tell me, thanks.)) with idle temps at ~33C and Load at around 37C (SK7, SmartFanII@5000RPM).
I decided to find the limits of the Proc. First, ran it at the 11.5x200 (Which it is right now) and it works great.
(That is Kingston ValueRam there, I had it running 2-2-2-11 @ 166 default voltage, i'm starting to burn it in now, giving it 2.7V)
Next, I up the multi to 12 and the Vcore to 1.775V
Not much in the way of ram there, it was running in 6:5 @ 2-2-2-11 with default voltage.
Thinking I can get 2.5, I try and hope for the best. Upping the Multi to 12.5 and Vcore to 1.925(My boards Limit), I pray nothing frys.
Yay, nothing Blew up. 2.6 Seemed in sight. I up the Multi once more to 13. Reboot, says its a 2600MHz Athlon. w00t. Go into the bios to check RAM timing, And it freezes. I reboot, nothing. Reboot, comes up again, but dont get past hard drive detection. Once more, nothing. So I reset the cpu frequency to default and head back to 11.5x200. Works great, and i'll try to get more once I get a new video card (i'm rather poor, so I have to save up for a While to get anything, which is why I only have 256MB ram)
I'll update this if I can get anything higher and stable out of this great little chip.
EDIT: Here's the steppings I remember, don't want to take off the SK7 for the Serial numbers.
AXDA1700DLT3C
JIUHB0310WPMW
AXDA1700DLT3C
JIUHB0310WPMW
