MSI 870-G45
Phenom II 955 x4 c3 3.2ghz
Corsair xms3 2x2ghz 1600mhz ram
Corsair TX650w PSU
Windows 7 64bit
XFX 6950 1gb
I noticed that I cannot push my CPU NB frequency past 2400mhz, i fail to boot, no beep, just black screen. ?
It seems I can get my clocks up to 3.5ghz using the multiplier but anything past that in Prime95 only ONE worker stops working while the rest keep going. My core voltages don't help either. I have gotten it up to 3.8ghz in the past by using core voltage of almost 1.5V + upping the CPU-NB volts to over 1.3v as well as putting the CPU-NB multi up to 13 and I passed a 6 hour prime95 test but I was playing Arma II and after some hours the game completely crashed and acted very strangely and my computer had to be rebooted. I can pass Small FFT stable, but when I do blend its only the one worker that fails. Is this a memory issue? I should also add I ran a 6+ hour metest and got zero errors. What should I do?
Edit: Just noticed that large FFT & blend almost instantly gives me 1 worked stopped but small is stable. Any help is appreciated. I suspect its memory.. again
Edit 2: I bumped my memory frequency down to 800mhz..instead of getting 1 worker stopped, this time i got a blue screen within 20 seconds. BSOD code was 101: which means not enough vcore. I tried it again at 1066mhz and this time I got a fatal prime error and 1 core stopped.
Corsair TX650w PSU
Windows 7 64bit
XFX 6950 1gb
