Now I wasnt sure exactly what thread to post this in so i chose this 1 in hopes that its the right one..Anyway..
Over the past yr or 2 I have been Slowly getting thing by thing until I had everything I need to build me a awesome fast reliable gamer quality pc.
Finally I made the beast rawr and I can guarentee U it is by far the fastest pc Ive ever used.
I decided to overclock as much as I could but with little knowlage, just research and trial and error until finally I got it to work stable under diff tests such as intel burn etc, but how do I know im getting the most out of my pc?
Perhaps I have a setting wrong and maybe im decreasing performance?Things like this I dont know for sure cause its all new to me..
Heres some of the hardware Thats in it.
Intel core2 Quad Q8300 - Default clocking 2500MHz. - Overclocked to 3450MHz. - I once had it all the way up to 3525MHz but it seemed unstable, according to battlefield P4F, so then had to downclock it...
Heres a detailed hardware report done by everest.
I reported this after overclocking it btw, these arent factory defaults.
Motherboard:
CPU Type QuadCore Intel Core 2 Quad Q8300, 3450 MHz (7.5 x 460)
Motherboard Name Asus P5Q Pro Turbo (2 PCI, 3 PCI-E x1, 2 PCI-E x16, 4 DDR2 DIMM, Audio, Gigabit LAN, IEEE-1394)
Motherboard Chipset Intel Eaglelake P45
System Memory 8192 MB (DDR2-800 DDR2 SDRAM)
DIMM1: Patriot Memory 6400EL Series 4 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
DIMM3: Patriot Memory 6400EL Series 4 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
Display:
Video Adapter NVIDIA GeForce GT 440 (1024 MB)
Monitor Acer E181H [18" LCD] (E05080034217)
Monitor HP F1503 [15" LCD] (CNK43806F4)
Multimedia:
Audio Adapter High Definition Audio Controller [10DE-0BEA] [NoDB]
Audio Adapter VIA VT1708S @ Intel 82801JB ICH10 - High Definition Audio Controller
Partitions:
C: (NTFS) 931.4 GB (764.2 GB free) WD Black edition
E: (NTFS) 298.1 GB (298.0 GB free)One from an old stock storebougt
Motherboard Properties:
Manufacturer ASUSTeK Computer INC.
Product P5Q PRO TURBO
Version Rev 1.xx
memory
DRAM Frequency 460.0 MHZ
FSBRAM 1:1
CAS# Latency (CL) 6.0 clocks
RAS# to CAS# Delay 6 clocks
RAS# Precharge 6 clocks
Cycle Time 18 clocks
Row Refresh Cycle Time 78 Clocks
Command Rate (CR) 2T
CPU
Core Speed . 3450.3 MHz
Multiplier x7.5
bus speed 460.0 Mhz
Rated FSB 1840.0 mhz.
PS no idea what this means, just typing it off cpuz
L1 Data. 4x32 kbytes|8-way
L1 inst 4x32 Kbytes|8-way
Lever 2 2x2048 Kbytes|8-way.
Now 1 question Thats really bothering me is the Strap to northbridge, And i know its prolly not that important but things like this bug me when I cannot find an answer.
With my cpu clocked at 3450/460 fsb, how should I set my strap to north bridge? 333, 400 or auto....
I still am trying to understand how this works and I wanna make sure I get the most out of my pc!
Or any other suggestions for me would be awesome!!!!
Motherboard:
Display:
Multimedia:
Partitions:
Version Rev 1.xx
memory
FSBRAM 1:1
CPU
Multiplier x7.5
bus speed 460.0 Mhz
