Hi,
My first post. I haven't done any overclocking for a while but decided to get started with a whole new system.
Specs
Asus Rampage VI Extreme
CPU: Core i7 9800X
Cooler Corsait H60 single RAD.
Ram G.Skill Trident Z cl15 3000MHz, 32 GB.
Power supply EGA Supernova 1600 G2.
EVGA GTX1080
Note:
I have a custom loop with a triple rad which will be installed later. It's currently in another system.
I started off with using the XMP profile for the ram. Applying all the automatic optimizations suggested with the bios, resulted in all 8 cores running at 4.1GHz. Kind of strange. The turbo boost never engages. This ran for 14 hours with a maximum temperature of 72C using Intel's Extreme Tuning Utility
Next, I selected manual overclock but the only thing I added was to raise the RAM speed up to 3000. Everything else is on automatic.
This resulted in all 8 cores running at 4.5gHz which ran for an hour or so but then crashed. Temperatures reached 80C
The next test was to run in manual mode, but I set the cores to be synchronized and raised the ratio to 44. This seems to be perfectly stable running for many hours (10+) but the temperature got to 83C. The triple RAD I have should do a much better job.
Before I go any further I will need the better cooling.
I have a couple of questions for everyone. It would seem that I can probably run perfectly fine all the time with all 8 cores at 4.4GHz. Is this OK or should I just put the turbo boost to bring everything up to 4.4 GHz when needed? Can this even be done? On stock, the CPU runs at 3.8GHz but the cores automatically go to 4.5, 4.5, 4.2, 4.2 ,4.1, 4.1, 4.1, 4.1
I guess there is not too much known yet about these chips.
Thanks, Tom
Specs
CPU: Core i7 9800X
EVGA GTX1080
Note:
Thanks, Tom
