- Nov 13, 2001
- Chicago.
1005E also supports the 2.4
The fsb can be change via the BIOS up to 150 fsb. No more need for jumpers at a high fsb. Also you can select from 1.1v-1.85v via the BIOS with no need for a vpin .MospeadasDark said:What's new?
AntmanMike said:1005E also supports the 2.4
MospeadasDark said:Anything I need cautioned before flashing?
Big Nuttz said:I'm rolling the P4T533C BIOS on my P4T-E and its awesome. No more need for those jumpers.
Nismo Nate said:
What version of the P4T533C BIOS? just the normal or the Beta 1003?
Or dose it matter?
:edit: oops it's in your sig Dirrrrr, wel is there anything i need to know before flashing, like i am going to have to reset all my previous MB settings corect? After you flash all your MB setting are reset so you have to reenter them right? or will all my boot settings stay?
- Thanks - Nate
MospeadasDark said:
disable all the things you won't be using(and can't use).
