- Apr 18, 2004
- UK...London...
Hello people...
My pc is made up of: zalman 400w psu, P4P800, 3.0 ghz not currently OCed, Corsair PC4000-PT cooled by a zalman reserator. At default settings the max temp is not touching 27 currently (AC turned on).
The problem is that I want to overclock the setup. I can get it to 3.6ghz using fsb:400, agp/pci locked @ 66.66/33.33, vcore 1.9, ram: 2.75v, agp: 1.50v. Memory accel is enabled and performance mode is set to standard.
At 3.6ghz it is not fully stable, I heard disabling usb legacy support could help and disabling spread spec as well, they are both disabled.
Ram timings are 3-4-4-8 with a burst lengh of 8.
I know I can go further with the components as the ram max's should max out at 3.7ghz. I just want to get to 3.6 as at this level I am really happy with the speed.
Can someone tell me what I am doing wrong. I know while OCing I set a very high vcore but anything less and xp crashes very quickly.
Also, there is a setting VID CMOS setting which is set to 62 by default. What does this do and do I need to modify it? I wan to run in a ration of 1:1 so in all my settings I have left the ram freq to 400.
I could really use someone's help...my pc is begging for overclocking...I reach a load temp of 42/3c when running at 1.9 vcore. I know I have the cooling at the components, just missing the know how.
Is there a setting most people do naturally that I am forgetting?
I would really appreciate your help as I think I am starting to kill my last brain cell banging my head against the
If you need more info on the setup please let me know, I am really getting angry as I spent money on getting decent ram so I could get decent performance.
Thanks in advance...
JenBell (noobie who should know better)
