gutaker said:tt wb doe not exist anymore in my rig, read reply no 25
...and i cant disable the virtualization coz i need it.
i run WinXP Pro for PCB design purposes coz Altium Designer DXP 2004 dont wanna work with Vista Entrprise x32 im now on ;(
but ill try... back to you in a few minutes
hi'(Clanger)(DOA) said:should be ok as long as you have a stout WC loop, I would creep the vcore up since you have that TT cpu block and watch temps. Also i meant to say disable Vanderpool Tech (VT).
hi'gutaker said:clear cmos with jumper and if there is no success flash the bios with your current bios.
flashing bios works for 100% done it a few times and VPT was always enabled to change, but after you save your changes for the first time there is no way back - only those mentioned above
cheers
hi'gutaker said:personally i prefer EZFlash within the BIOS
its always a pleasure to help someone
