- Dec 6, 2005
- New Hampshire
ok, i'm sorry to have to start another P5W thread, but I need some help here, this is my first real OC. I just put together the rig in my sig, and my ram isn't running at the right speeds or timings. I set it to manual in the bios and seledted ddr 800, bit it's only running at 350 mhz, 5-5-6-18 (should be 400, 4-4-4-12). I also can't seem to find where to manualy set the timings.
My second question. When I oc my cpu, it automatically is overclcoking my ram. I can't find a setting to lock the ram frequency into 400 mhz (once i actually get it to run at 400 anywyas.
Lastly, my cpu voltage is set on auto. Does this mean it's kicking up the voltage when i'm ocing? I want to keep this on stock volts. To do this, what do i need to do, find out what the stock volts are, and then select them in the bios?
Thanks alot for your help!
