I have the Asus P6X58D Premium, i7-930, and Corsair XMS3 6GB(3x2GB) "TR3X6G1600C8 G" currently.
Im looking for an upgrade in my memory for a reasonable price.
The QVL list for the mother board has this memory as a single triple-channel configuration, and not supported for dual triple-channel configuration.
I was aware of this when I purchased them and decided to deal with this when i wanted an upgrade.
Should I just buy another 6GB of the same memory and ignore the QVL list?
If it says its not supported, then can I not run 6x 2GB modules at 1600mhz 8-8-8-24? Or is it no one has tried and found out?
Or should Ii just go for any 12GB(3x4GB) kit with good timings? There is no memory listed to run at 1600 mhz & 8-8-8-24 in a triple channel config.
Regardless if purchased as a 3x4GB set or individual 4GB modules bought seperately.
The only memory I can see on the QVL list that has equal/better timings at 1600 mhz in two triple-channel configs is the OCZ Technology 6GB OCZ3X16LV6GK.
After a quick search, I found them to be $200 roughly for 1 triple set. Thats $400 to switch memory and add 6g while keeping 1600mhz & 8-8-8-24 timings.
Is my current setup fine and im wasting my money?
Any insightful information is greatly appreciated.
Additionally:
I am not currently in XMP mode and have manually input my cpu/memory values. I am just starting to dabble in overclocking.
Do I need to be? Is it better than manually input values?
Additionally:
