- Aug 8, 2001
- Sunshine State, USA
PhobMX said:
omg, those must be the noisiest fans eva!!!
The quiet one is 41.5dBA at 12v and the one MrB has is 56dBA at 12 volts
archilochus said:BLKGTI,Can I get dibbs on your surplus fans?
archilochus said:I got you a link to a pic STAN03, About your q above! Thats a cool
little fan. (thread jack, sorry)
HDD COOLER PIC
Blkgti,Have you ever run one of those Aero blowers on your HS yet? I forget,but I think 7Keys was very curious about the results of said fan on a HS. Thanks, THE FANMAN
archilochus said:Dood I've thought about those for sure.My plan was to put it at the bottom of the mobo,blowing towards the top of the case.This
would push a curtain of air up the mobo cooling it.
Did you check out that other HI-PERFORMANCE rig? THE FANMAN
archilochus said:Can't you use a 80mm x 25mm fans body for a spacer or standoff? Thats what I had in mind.But until I get the fan I won't know for sure!
Been looking at some higher powered Centrifugal Blowers in the mean time.What is your source on the Papst fans?
THE FANMAN
blkgti said:
IIRC, it's ~40cfm @ ~36dBA. That said, IME, CFM/dBA ratings are almost never indicative of the fan's actual performance.
FIZZ3 said:It says 16v/8v DC on the fan though. So does this rating correspond to the 16v input?
In a 12v DC PC case you'd be undervolting them a bit... altough that can be fine to prevent annoying sound production.
blkgti said:They weren't that loud when I ran them powered from the rear Molex on a TC550, but I've yet to actually try them inside the case. I'm expecting them not to be very quite, though, as their all-metal construction may ring a bit when attached to the case. With that in mind, I plan on using Vantec silicone vibration dampeners during the install.
