- Jan 12, 2013
- Colorado Springs, CO, USA, Earth
So I upgraded my desktop, I got a new motherboard, power supply and processor. For some reason though it simply will not POST when I turn it on.
For one thing, my case's power switch apparently no longer works, so I have to do the whole thing with the screwdriver on the power switch pins to get it to turn on. I don't know if this is somehow causing the problem, but...
I have tried changing out the RAM, only putting in one module, reseating the heatsink, trying a new heatsink, reseating the CPU, reseating the GPU and trying it without the GPU altogether, disconnecting the PCI wifi card along with all the SATA devices, reseating all of the power supply cables, taking out the coin battery... I don't really think there's anything I haven't tried yet, but it simply will not beep. All the fans and LEDs turn on along with the hard drives, and it sounds like the computer is functioning, but I don't hear the POST beep and the monitor does not get any signal, the mouse and keyboard do not turn on either.
This is the system:
CPU - AMD Athlon X4 750K Trinity 3.4GHz
RAM - 4x 4GB G.Skill Ripjaw 1333MHz
Motherboard - MSI A88X-G43
GPU - EVGA NVIDIA GeForce GTS 450
PSU - Thermaltake SMART Series SP-650PCBUS 650W
Storage - 1x 128GB SSD, 1x 1TB HDD, 1x 750GB HDD
What could be going on here? Another piece of information is that one time I accidentally did not plug in the 8-pin CPU connector into the motherboard and tried turning on the computer, and it functioned exactly the same as it did when I did have the 8-pin connector connected, like it wasn't doing anything.
The processor should be compatible, right? It fit in just fine, but I'm not really used to AMD... (not to mention the hell I go through every time I try to reseat the stupid clip-on heatsink to it)
This is the system:
