- May 26, 2003
Edit: Found this post. I think I'll sleep on this and look at it more tomorrow. I wish you could delete posts here.
This seems to happen randomly on a motherboard I've had installed for about a year. I can't say it happened enough to say it's always done this but with the other motherboard it never happened. Anyone have an idea how to reproduce this to make it easier to narrow things down? Things I've did:
* Tried 3 different PSUs
* Reseated the motherboard
* Checked case wiring multiple times and rewired a few times already
It's an old Antec 900 case but I have no need to replace it. I can't say it doesn't happen with the back panel but I haven't tried it enough. I'm going to guess a motherboard issue. If it's a grounding issue somewhere, you'd think I could touch the ground on those components and get a measurable voltage but out of curiosity, I checked it with a DMM and only have 13.1mv between case and earth ground. I don't know if that's anything significant though. Is this something to worry about? I don't really want to replace the case or motherboard. Also it happens with the front panel usb/3.5mm audio jacks and the card reader/usb device on front connected to the motherboard. I've also had two HDD's fried at the same time months ago which I thought was suspicious of an electrical issue.
