Excuse the spelling please
Basically an upgrade from a Intel to a theoretically faster spec AMD , but kept memory and GPU . Reason being Intel CPU failed twice in 2 years
OK well Comparision spec
Old INTEL Rig i5
Intel I5 760 2.8 Ghz = OC 3.4 Ghz
Gigabyte H55M UD2H
Video Card HD7950 Windforce
OCZ Vertex 100GB Sata 2 SSD
Corsiar XMS3 DDR 3 1600Mhz 16 GB Dual Channel , Ganged
New AMD FX Rig
AMD 8350 Bulldozer running at stock = 4 Ghz
Asrock 960GM/U3S3FX ( Sata 3/ USB 3)
No change here Video Card HD7950 Windforce
Samsung 840 EVO Sata 3 SSD
Corsiar XMS3 DDR 3 1600Mhz 8 GB Dual Channel ,
Now here is the interesting part , On the Old Intel Rig , whilst gaming maxed out (all settings)the gir could achieve solid 60fps with 1-5 fps drop , on Alan Wake, for example .
Have also been playing Grid autosport and am getting slowdown even on lowest settings ( except 1080 p)
Now I just played Alan wake on this new Rig and am seeing frames drop to 20 FPS on Max settings
This is really weird
Running Catalyst 14.4 with latest graphics drivers ( inluded in 14.4 package)
Ram Timings are set manually
Both Rigs had been running Windows 8.1 Pro 64 Bit and running programs on the same secondary 5400 RPM HDD
Quirks I have noticed , new rig is running Sata 2 ports HDD's in IDE mode , . However Sata 3 port is Sata mode and running at sata 3 speed ( Asmedia 106 Controiller) Using just one Sata 3 port of two provided
Both Are M-atx boards , this is the only sata 3 matx board I could find but it is making me suspicious . The board does however run the SSD at almost Sata3 top speed ( around 450/500 mbps) . Should on theory be a faster build
Any Thoughts ?
Old INTEL Rig i5
Gigabyte H55M UD2H
New AMD FX Rig
Any Thoughts ?
