I found you lose a huge amount of performance when you stray away from 2-2-2-5 timings on slow stuff like SDRAM. If you've ever run a full loop of Memtest, it takes 30-45' - at 2-2-2-5!!! My RDRAM boards click out a full loop in 5-6'.
To get 2-2-2-5 above 150 fsb with 512 MB ram on Coppermines I use my CUV266 boards, which uses DDR. It doesn't bench better, nor does it get significantly better bandwidth, but finding DDR to run 166, 2-2-2-5 is a piece of cake. Morever, the board offers up to 2.8-2.9 VDIMM I think, though I never had to use it. Only caveat is it's a Socket 370 board so can't run my Slot 1s.
However, if you are running dual P3s, you are pretty much out of luck with a DDR board.
