T tommycarl1 Registered Joined Sep 1, 2019 Dec 18, 2019 #1 Would adding the Phanteks RGB fan frames affect the performance of noctua fans? Thanks
Blaylock "That Backfired" Senior Member Joined Jun 5, 2013 Location Go Blue! Dec 18, 2019 #2 I doubt it would make any noticeable difference in performance.
ehume Member Joined Oct 30, 2009 Dec 19, 2019 #3 tommycarl1 said: Would adding the Phanteks RGB fan frames affect the performance of noctua fans? Thanks Click to expand... Given the effort Noctua puts into their research, it's possible that using another company's frame will make the performance worse.
Blaylock "That Backfired" Senior Member Joined Jun 5, 2013 Location Go Blue! Dec 19, 2019 #4 I think he's referring to these ED, not actually replacing the fan frame. Phanteks PH-FF120RGBP_BK01 Halos RGB Fan Frame If he is talking about replacing the frame then yes, absolutely it would alter the fans performance.
