- Nov 24, 2011
temps still looks way too high for 3.4GHz, temps look more like 4GHz
but with that much vcore i would expect 3.8 or 3.9GHz
OC manually, never trust 'auto'
leave you vcore where it is and up the clock still you find the max stable clock
here are my temps (similar system, prime ran for 20-25min)
hyper 212 evo on a phemon II 965
the evo version is only about 1 or 2 C better under load than the plus version
my vcore is set a 1.5125 in my bios (clock speed is 4.2GHz)
the pull fan on my cooler is unplugged, so it only has the stock fan
Code:
atk0110-acpi-0
Adapter: ACPI interface
Vcore Voltage: +1.45 V
+3.3 Voltage: +3.43 V
+5 Voltage: +5.08 V
+12 Voltage: +12.52 V
CPU FAN Speed: 1717 RPM
CHASSIS FAN Speed: 931 RPM
CHASSIS FAN 2 Speed: 675000 RPM (RPMs are too low to register right)
CPU Temperature: +57.0°C
MB Temperature: +30.0°C
k10temp-pci-00c3
Adapter: PCI adapter
temp1: +55.1°C (high = +70.0°C)
(crit = +90.0°C, hyst = +88.0°C)
