- Aug 3, 2005
- /home/tn/johnson city
Very nice OC. What kind of cooling are you running? Stock HSF? I plan on getting one of the 3800's myself in the near future and seeing this motivates me even more
Robert said:It is a Thermaltake Tower 122 Cu with Vantec Tornado 80mm @ 3300RPM.
It is about the same grade as Cooling Master Hyper6 I think.
Robert said:njkid32 -- about 15c drop, That is really good. I think you can go even higher than 2.8Ghz now.
hitechjb1 said:For Venice, SanDiego, FX 55/57, Toledo, Manchester, the SuperPI 32M score per clock should be above 13.5.
Winchester/ClawHammer ~ 13.0, NewCastle < 13.0. Tbred B/Barton ~ 11.
SuperPI_32M_score_per_clock = 1000000 / (run_time_in_minute * CPU_frequency)
In your SuperPI 32M run,
CPU at 2690 MHz
SuperPI_32M_runtime = 28.9 min
SuperPI_32M_score_per_clock = 1000000 / (28.9 * 2690) = 12.9
So it seems to be on the low side. That maybe due to the fact that two SuperPI 32M were being run concurrently.
You may try to run just one instance of SuperPI 32M to see whether the score can be improved.
Comparing various CPU cores based on SuperPI 32M run time
njkid32 said:I was running 2 prime's to see if I was stable at 2.9 1.65v and it ran for about an hour. So right now I am at 2.4ghz 1.26v and am going to do a burn-in overnight. How is your coming?
You are lucky that thing didnt burst outRobert said:2770Mhz @ 2.725v .
Robert said:I'm still burnin the X2. So far, I set to 2740Mhz at 1.62v
I try 2770Mhz @ 1.725v and it seem stable. But, I don't want to run that high voltage.
njkid32 -- Why don't you do some test with Superpi 32M?
Sucka said:You guys are running some seriously high voltage at those clocks. When i go over 1.6v on air temps just skyrocket (of course i used silent cooling for my testing). Mine didn't get any better from burning in. It also has a hard time over 300HTT which makes UTT pretty worthless on the X2 in my case, as i need to go well over 300HTT to max the memory. How high can you go max on HTT with those chips?
njkid32 said:Burn-in has helped me some cuz I am able to clock higher with lower volts. The highest I have had my HTT is at 300. You can see my ss a few posts back. I just did that to see if I could. I am trying to keep my volts low cuz this chip runs alot hotter than any of my others. It did make a huge diff when I removed the IHS.
I am also using a divider right now so I can max out my CPU but my Redlines can do about 260 2-2-2-5. I havent really spent much time on my ram though I need to burn them in a little before I start pushing them.
