I've read pretty much everywhere that the max safe temperature for a 955 is 62C, but I can't seem to get anywhere near that low at max load.
At the moment, I have only a very tiny overclock - 3.4GHz, 1.360V. I can't seem to get any higher than this stable no matter what I try. It won't even boot if I go above 3.6GHz.
With an ambient case temperature of 33C, it idles at 42C and at full load gets up to 68-69 cpu temp and 69-70C core temps. Even at stock settings, it runs at similar temps.
This build is 3 years old and has been running almost 24/7 since it was built (though in the last few months I've been trying to get into the habit of putting it to sleep when I'm not using it). The CPU is C2 stepping, not C3. The case is in an Antec 300 with 140mm top exhaust fan, 120mm rear exhaust fan, 120mm side intake fan and 120mm front intake fan, all set to their highest settings. All fans are working properly. The HSF is an Arctic Cooling Freezer 7 Pro and its fan is also working fine.
I've tried reseating the HSF, to no effect. I also routinely clean out dust from the computer and the front fan filter, and did so before taking these readings.
I do intend to replace the case with a HAF 932 when I have the money, but even in this case, it should still be possible to get temperatures below 62C, shouldn't it?
What else can I do to get a more reasonable temperature? And why can't I seem to get it to run stable at anything over 3.4GHz? Even with C2 stepping, it should be able to get to around 3.8GHz, shouldn't it?
