With ht 8KHA+ befor I killed it, was able to run 166 fsb no problem.
This Dragon plat will only do 144 fsb with everything relaxed, even with the cv up to 1.8 on H2o, Corsair XMS2700, much over that and it locks up, will go into windows tha run a lill while then lockup NO BSOD though
And even locks while running "TOAST" so not @ al stable.
$heet my Abit KT7-E is a 100 and will do 133.
I know it's not the CPU or the ram for they have both been up to 166 FSB, on this mobo any thing much over stock and it locks, and I jusr had the same CPU on the MSI mobo @ 1.6
If it does not get any better in a week, back she goes "DOA" and comp show, epox here I come back.
And only 1.8 cv, the 8ka3 goes up to 2.2 or 2.3 cv.
When I can get a mobo that will do 180's and up FSB and a CV over 1.85 for around $90.00, it sure beats this plat @ $150.00
And the most mem score was 2202, SAD
EDIT:
Seing this is my first Soyo what are all the settings you guys are running?
This is the Dragon Ultra Plat KT-333 with an XP1600+ AGOIA.
Gona try and change out the XP1600+'s between the Soyo and MSI.
No difference with the swap, I sure do like the Swiftech H20 2 screw hold down.
Now with them switched back, I noticed that the CPU: Dram Freq-100:100/133/166, the CPU-100 NO longer changes with changing the CPU Freq Select or CPR Ratio select, where's it did befor. lookzzz like DOA for me.
133x10.5 for now-1.4. lucky me, NOTTTttt.
Thanks Guysz!!
