- Sep 9, 2002
- under the floorboards
Well I finnaly got around to installing Red Hat 9 on one of my drives and have run into nothing but problems.
#1- No wireless lan- Seems to have ever wlan device built in EXCEPT mine So, I look for linux drivers (which fortunatly exist). Unfortunatly, I find that linux drivers work in no way similar to user friendly microsoft drivers.
I have a Linksys WUSB11, so I go to their site and download the .tar file (I assume thats basically a zip). I untar it (in a folder on my desktop- goes to /home/myusername correct?), and end up with no exe file or anything I can actually run. So, I go to trusty old google and find a tutorial. It tells me:
log in as root in the console (done)
compile the driver (huh?)
Thats where I am confused
It says to go to cd/root/drivername
but I didnt put the driver there- anb typing that command does nothing that I can see.
So I type cd/were I actually put the driver
Says no such directory
Confused, I just type the path of where I put the directory- output as follows
[bash] path exists (or something like that)
So am I reading off the directory??? (im so used to dos)
Next thing the tutorial says is to type 'make config'
it says no such command
So I try just make config
and it says something like it does not recognize target config
If that had worked, the tutorial tells me that I should get a command line instal program running.
#2. My dual monitors dont work. It recognizes my second monitor as my main one (wich is a small 17 i have on top of my 21) unless I unplug the second monitor. Is there a linux driver for this?
#3. I installed Linux on a small removable hard drive. However, when it installed, it overwrote some of my main hard drive to give me a dual boot screen- it gave me no option not to do this (i just wanted to dual boot through bios and leave my xp partition). Now, my system wont boot without the removable drive (if i try, it gives me GRUB error)- hardly desirable since I used other drives in that reovable tray.
So... Anybody know what I am doing wrong? Im sure Im missing some big concepts about the linux operating system.
