pokerchachacha
- May 27, 2014
Hey,
I decided to replace my old desktop with a High end performing machine. That is what i have in mind:
already bought: ( i live in europe, i will convert the prices from euro to us $, also please note europe is more expensive than the US.)
-G.Skill TridentX DIMM Kit 16GB, DDR3-2400, CL10 (Used on ebay: 130$ )
-Intel i7 4930k ( sealed ebay: 550 $ )
intending to buy:
-another G.Skill TridentX DIMM Kit 16GB, DDR3-2400, CL10 Set
(new 200$ ). Do i need 32gb of RAM? and can i mix it with the used ones already bought?
- 3072MB EVGA GeForce GTX 780 Ti Superclocked ACX Cooler Aktiv 03G-P4-2884-KR
( used on ebay, about 600$, seller says only used for videorendering for 4 weeks ....or better to buy new for 800$ ?? )
- Asus ROG Rampage IV Black Edition Intel X79 So.2011 Quad Channel DDR3 EATX Retail (New:500 $)
- 1000GB Samsung 840 Evo Series 2.5" (6.4cm) SATA 6Gb/s TLC Toggle (MZ-7TE1T0BW)\
( ebay:sealed 450$ ....i know i could go RAID, but i need to be safe cause of my work.)
Whats missing still:
Case, PSU, and what cooling should i use? Anything else?
Would those components all fit well together and are those prices reasonable?
About the Case or PSU and cooling i really dont know at all.
What windows version would you recommend me? Anything else i need to consoder?
Thank you so much for your time, you guys are awesome.
PS: i tried to do a wishlist on newegg with all the components, might be easier for you. hope you can access it. thanks!
https://secure.newegg.com/WishList/MySavedWishDetail.aspx?ID=30433687
intending to buy:
