- Sep 8, 2002
- Chicago
Ok I am trying to remove the HSF from my radeon 9700. I popped it in the freezer and slid a credit card under the hsf and then used a screw driver in between the hsf and the credit card to pry it apart.
My question is this. There are 2 pins that go through the card that are holding it down. How are these removed? Do I need to squeeze the tips of these to slide them back through the card. From what I can see it doesn't look as if these tips could squeeze together but I am being cautious because I am not even sure that this is the correct method to remove them.
Thanks in advance!
Thanks in advance!
