32 bit is the ONLY way to go for gaming rig as there are no games made even today for a 64 Bit OS .
I only know that the XP Pro 64 bit one will not run my programs such as reg mechanic , spyware doctor , wash and go , windows washer and my LG monitor drivers as well
So have you ever used Vista SP1 x64?
Can you tell me if you DiaBlo II will work OR any of the home world games will work on the Vista 64 Bit OS ? This is what I have been wondering and what has kept me from getting the 64 Bit Vista OS .
Can you give me one good reason why you wouldn't go for 64-bit?
It costs the same.
It has better performance.
It has better memory management.
It works with 32-bit and 64-bit applications.
It has the same amount of hardware support on the Vista platform.
What's the negative?
Edit: And your little list is FAR from comprehensive. You're missing quite a number of titles... All the Unreal (and unreal-engined games) have 64-bit capability. Id Tech 4 engines too. And where's Crysis? And the gammut of games that use the HL2 engine (Team Fortress 2, Portal, HL2:Ep1 and Ep2)?
Cool maybe I will get sooner than later then . I wounder if I can upgrade my vista home Premium to the 64 bit ?
