- Sep 5, 2002
- Toronto, ON
For the most part the newer 1700+ Tbred B dlt3c chips seem to run a lot hotter than the others, at least when at high clockspeeds. I think it would be good to get a better idea of just how much more heat they produce though, especially for those considering purchasing one and needing to know what kind of cooling they will need. The issue about some motherboards not reporting the temperature correctly is another complication in actually getting a good measure of this.
Please provide the following information if you have a Tbred B. The ones that will be most interesting for this are the 1700+ varieties, but having the temps of others in there won't hurt either. Please just report what your motherboard reports to you, not an adjusted figure, even if you think that it is inaccurate. This will remove any subjectivity and will still allow us to compare CPUs to others on the same motherboard.
Here's my info:
CPU Model: 1700+
Stepping/week: JIUHB 0310WPMW
Default vcore: 1.5v
Current clockspeed: 2406MHz
Current vcore: 1.8v
Motherboard: Abit NF7-S rev. 2.0
Bios version: 1.0
Cooling: Vantec Aeroflow
Idle surface temp.: 52C
Load surface temp.: 58C
Idle diode temp.: Not reported by motherboard
Load diode temp.: Not reported
As you can see this is very hot, about 15C higher than my old 0302 on my KD7. It could also be an inaccurate temp. sensor, this could be one of the things that comes out if we get more results.
Here's my info:
CPU Model: 1700+
Default vcore: 1.5v
Current vcore: 1.8v
Bios version: 1.0
