me12345 said:You may have just burnt it out. Ideally, you should borrow a CPU or buy one from a store that allows returns, just in case it turns out to be something else.
Kendan said:I hope it is the CPU otherwise I have no idea what it could be Maybe a Virus... hmmm well lets hope it is the CPU which is cheaper than the motherboard anyways
diehrd said:I would disconnect all drives Except the floppy and see if you start up. Of course with no drives attached instlation will not happen but It will confirm if the drive and or cable on the IDE channels are an issue..
Have you tried a 98 boot disk ?
Also can u swap memory ? Or take it to a small local and let them test it on there testor ?
Zuzzz said:ummm how much for the used mother board???
Z
