Are there any known issues with fitment of compression fittings on the Apogee XT using 1/2" ID x 3/4" OD tubing/fittings?
I know they come with regular barbs and the general concensus is there is no gain of using compression fittings, but i like the look of them..
I think it's called the "alternate mounting" in the instructions: Remove the inlet plate, turn it 180 degrees and re-install it. Make sure the o-ring is in proper position before re-installing the inlet plate. It's made to do that for larger comp fittings.
