Hello!
The time has come! I purchased a CaseLabs Mercury S8 for more than a year ago, the plan was to start with the new project as soon as I received the case but I never managed to start building due to work and some other projects. I'm finally done with all of my other projects so I thought it would be a good idea to start building again!
Here's a list of all the components and all of my plans for the build, I'll most likely add some more ideas in the future. If you guys have any tips or ideas then make sure to share if you'd like!
[size="+1"]~Hardware~[/size]
Case: CaseLabs Mercury S8 Gunmetal
CPU: Intel i7 6700k
MB: EVGA Z170 FTW
RAM: G.Skill Ripjaws 4 16GB 3000MHz
GPU: 2x EVGA GTX 780 SC
SSD: 4x Samsung Evo 540 256GB
PSU: Seasonic Platinum 1000W XP2
Fans: Scythe GentleTyphoon AP-15
[size="+1"]~Watercooling~[/size]
Rad 1: Black Ice GT Stealth 360
Rad 2: Black Ice GT Stealth 360
CPU Block: EK-Supremacy EVO -Acetal+Nickel
GPU Block: EK-FC Titan XXL Edition inkl. Backplate
RAM Block: EK-RAM Monarch
Res: Bitspower 150mm Water Tank Z-Multi
Fittings: Bitspower Angles: 90/60/45/30, Extensions: 20mm/30mm, Compression 1/2"
Tubing: Masterkleer White 1/2"
Pump: Swiftech MCP655
Pump Cov: Bitspower Pump Mod Kit Deluxe White
[size="+1"]~Plans~[/size]
Print out some cable management modules for the case and the PSU.
Sleeving.
Modify the perforated metal and mount it in the case.
Plan the lighting.
~TBA~
