- Mar 31, 2005
- Stealing your megahurtz at night
my Coolermast PSU doesn't come with cable sleeving, except for the 24 pin cable.
so i got a whole bunch of yellow and red wires through my Antec 900 (which coincidentally doens't have cable management either lol).
if i can cable sleeve each cable, so non of the yellow/red sticks out, my cables will look invisible anyway...as i've painted my 900 black.
and besides the cool aesthetics, individual sleeving makes the cables more bendable/flexible
I have an Antec 900 as well, but I also modded it for cable management. The only PSU cable you can see more than 2" of is my 6 pin PCI-E cable. The point of cable management is to increase airflow through the case, and some aesthetics. In that case, you only have to be able to flex or bend the cables once, as long as you plan for it carefully. The way I have always done it, is to look at the case, and envision the system installed in the case. Once I have the picture in my mind, and sometimes even set the mobo in the case to help aid in planning my cuts. Once I have that all done, I can figure out exactly how I will route the cables, make my cuts, clean up the shavings, route the cables, and assemble. From that point, I don't need the cables to be more flexible, since I won't be moving them again. The closest I have come to moving them, is inplugging something for replacement.
