- Jul 12, 2002
I've experienced a quick power surge in my PC room twice now in less than 24 hours. The breaker for that room is not tripped and power comes back on within a couple of seconds. It's also not effecting the entire room, just one half of it. The half that I have my PC connected to and other gadgets. The other side of the room where my modem/router is connected doesn't go through the power surge.
Any ideas? My PC is connected to a 8 outlet APC Power Bar.
What has changed is I've purchased a new PC case and a Hydro Series H100i V2 CPU cooler...everything else is the same.
1) Could it be that I had "allow the computer to turn off this device if not in use" setting in USB power management settings in device manager? I have recently started using the USB header on the mobo for the Corsair Link
2) Could it be that I disconnected the HDD light cable from the mobo so it's not constantly flickering due to HDD activity?
3) I checked the outlet with a voltmeter and both plugs are giving out the correct voltage...though I'm quite dumb when it comes to electricity so I'm not sure this test had any real purpose.
4) Just noticed I had accidentally plugged in green audio cable into the Mic (pink jack)...not sure if this could have caused it?
That's all I can think of, please let me know which things above I can rule out.
I'm guessing it could also be a faulty cable? I've unplugged almost everything that doesn't need to be always plugged to troubleshoot this further. Started using a new HDMI cable for my 2nd monitor...so I unplugged that for the time being also.
