- Dec 20, 2001
I havn't noticed anything different. I seems to me that it was just a rearange of the menus, and some different default settings. I notice no extra speed or o/c ability. I am so close to giving up on this MB.
Ok I have done some testing with the 2800+ Barton, heres what I can get (all with CPU Interface enabled)login211 said:Hood are you saying that 9, 9.5, 10, 10.5 all work for you at fsbs over 225 WITH cpu interface enabled??
btw what improvements have you guys seen with this bios? this is the only bios that ended up getting corrupt for me, i had to get another bios chip.... i may try it again if it improves sandra scores and what not...
i'm sticking to the tictac bios 22 betaking for now :/
9.5x max was 250 on 1.7v chipset
10x & 10.5x max was 225 on 1.7v chipset(never tried with lower voltage though as I have heard that can help sometimes)
11x max was 235 on 1.7v chipset
11.5x max is 235 but this is the CPUs limit.
Hood
What I am saying is it looks like my mobo AND the 2800 have the 10/10.5x multi issues. I didnt have these issues when I had a 2500+ Barton in, so to me it seems relate to CPU/mobo combination rather than just an individual mobo.login211 said:i'm not sure what you mean by max but let me ask you this:
with cpu interface enabled, what happens when you set the bios to 10x227? the vdd is unimportant
if you are unable to boot then yes your mobo has the multiplier issue like all other nf7s...
Afraid not, PR3ACH3R is still working on it, he likes to make sure things are OK even before he releases it to the testers.Aragorn Elessar said:Any ETA on the revised PR3ACH3R BIOS?
iLLestOne said:I had a metal lever'ed (cpu) nf7 and could use 10 and 10.5.
I now have a plastic lever'ed mb, and can't use 10 or 10.5 even at 210fsb.
I dunno if this helps...I just think some mb's for some CRAZY reason can't handle 10 and 10.5
Hood
The Coolest said:I just wanted to know if this BIOS will work on NF7 rev. 2?
I might just give it a go when he releases the newer one.
Tony420 said:the download link is dead on the website...can anyone send me this file
