That's an impressive fan if those specs are correct. Most low-speed fans that are quiet only produce around 1mm H20, give or take 1mm.
A 30fpi rad is not going to like a low-speed fan, regardless of the static pressure. It will work, and you may be able to cool your gear, but the performance is going to take a serious hit, IMHO.
I can't speak for the fan unless you can tell us what type it is, size, rpm.
The fan in question is a Delta AFC1212D-PWM.
Of course, with it being PWM, the system could control the speeds. It varies from 25% signal at 1720RPM, 50% signal at 2420RPM, 75% signal at 3150RPM, and tops at 3400RPM.
Even in the 25-50% range you should get pretty high pressure, and still decently low noise, unless I'm just off-the-wall with my assumptions (which has happened)
Haven't used that fan...the specs almost seem too good...at $18 I think it's worth a try.
If noise ain't a problem which won't be with the selection of the rad, it should be perfect for it. I know on a 20 FPI rad (BI GTX 360) sweet spot is 2200 RPM (300w) in benchmarks. Anything less and you're losing performance. So I can imagine you'll need more than 2200 RPM on that rad.
if it ain't enough, just go push/pull at 50% to overcome the 30fpi with less noise as one Delta at full speed
