So I have an i7 860 processor, with an ASUS P7P55 LX mobo, 4 chips of DDR3 Corsair 1600Mhz RAM, and stock fan(a better one is in the mail, along with 3 fans to attach to my case so that I can increase airflow).
I used overclock guides listed in this forum(thanks again for that!) along with about 6 other threads on 6 other websites since most people don't overclock with my mobo and processor(I didn't realize I was going to overclock it. . .I mean it is eight 2.8ghz processors lol, so I didn't really research for a good mobo to OC).
So most of the guides say to run Prime95 or other stress testing software on each reboot to find out what is 'stable'. What does the term 'stable' really mean?
I understand that I need to run it for 12+ hours, but does it need to run that long without rebooting(like from overheating), or does it need to run for 12+ hours with ZERO errors?
When I run Prime95 I have 8 'workers', on settings that give me 180 BLCK/FSB on each processor at a total of 3.420Ghz(multiplier of 19). All other settings(besides RAM) stays on auto.
I've had Prime95 stress test using the top option(processor) and 'worker' 4 and 5 give errors immediately and then after 5 minutes 'worker' 2 gives an error(which makes those 3 workers stop testing).
Before that 3rd one errors, the CPU temp gets up to 74C, and when that one drops it goes down to 71C, and then Prime95 runs without anymore errors for however long I run it.
I have a 430W PSU(that came with the antec case), which is going to be replaced this week with a 650W corsair PSU.
Are these errors important since my computer doesn't reboot? Or do any errors at all constitute a reason to lower the voltage, raise the multiplier, etc?
Quick specks on my OC. . .
1.26 Vcore
19 CPU Multplier
180 BCLK
Another quick question about FBS vs Clock Speed. Everyone seems to want to use the highest multiplier possible. Which is a great way to increase the clock speed, but lowers your FBS correct?
My goal is to at LEAST get 3.5Ghz stable with the highest possible FBS. But what I will continue to work on and go for is something like 4.0Ghz with as much FSB as possible(I hope over 200).
And one more quick question about RAM.
I was going 3.5Ghz stable, but had a very low RAM frequency/ratio. I was able to give it a little more Vcore power and lower the clock speed to 3.420 but get my RAM at 1440Mhz at 1.65 volts(with 9,9,9,27 timing).
Spec it should run at 1600Mhz at 1.65 volts with 9,9,9,24 timing. But my board can handle upto 2200.
So if my math is correct, to get my RAM at 2200, I'd have to get my FBS/BCLK to 275? Do you think that will be possible with 4 case fans, and this heatsink( http://www.newegg.com/Product/Prod [...] 6835186134 )? If not what would my best shot be? 250=2000 200=1600 and 225=1800(first # being FSB second # being RAM Mhz).
I always thought overclocking just increased clock speed(cause I never looked into it, seemed too risky to me), and I've always favored FBS to clock speed. But I have literally been up for 60 of the last 96 hours reading forum to forum and doing tests of my own. So I've learned a LOT. I can do a basic OC, which is what I have now, but I'd really like to learn how to get the most of my hardware(with air cooling).
TIA to anyone who can help. I've held myself back from posting questions until I was familiar with what I was doing(and could actually understand the advice I'm given).
1.26 Vcore
19 CPU Multplier
180 BCLK
